Automatisk verktygsmätning
Makro för mätning av verktyg på fast mätstation, längden läggs in i verktygsregistret, fungerar även om man bara kör med ett verktyg men fungerar inte om Tool = 0, så kom ihåg att byta till tex verktyg 1 vid varje uppstart, alternativt lägg till koden för att spara verktygsnumret till nästa uppstart som finns info om i en annan tråd.
Code: Select all
//Simple Probe for setting tool offset
//This routine probes in negative Z at the current XY location
//Z offsets for G54 to G59 are then re-written to the new Z0
double ZRetractHeight = -1;  //Height above Z0 to which probe will retract
double CoarseRate = 500; //Feedrate for initial probing
double FineRate = 50;  //Feedrate for fine probing
double Zmin = -200; //maximum probing distance
double PlateThickness = 0;  //thickness of the probing plate
double MaterialOffset = 0; //compensation for part thickness
double CombinedOffset = 0;
int Currenttoolvariable = exec.Getcurrenttool();
double Zmachposvariable = 0;
double XToolSetPos = 80.05;
double YToolSetPos = -27.68;
double ZSafePos = -1;
if(!exec.GetLED(56)||!exec.GetLED(57)||!exec.GetLED(58)) // If machine was not homed then it is not smart to do this, stop here...
  MessageBox.Show("The machine was not yet homed, home the machine before setting Z-zero");
  exec.Stop();
  return;
if(Currenttoolvariable == 0) // Tool cannot be zero
  MessageBox.Show("Current tool cannot be zero");
  exec.Stop();
  return;
exec.Code("G53 G0 Z" + ZSafePos); // Move to Z0 position
while(exec.IsMoving()){}
exec.Wait(200);
exec.Code("G53 G0  X" + XToolSetPos); // Move to X position
exec.Code("G53 G0  Y" + YToolSetPos); // Move to Y position
exec.Wait(200);
exec.Code("G91 G31 Z" + Zmin + "F" + CoarseRate); // Probe Z quickly to get rough height
exec.Wait(200);
exec.Code ("G00 Z" + 1.3); // Retract .05" above the plate
exec.Wait(100);
exec.Code("G31 Z" + Zmin + "F" + FineRate); // Probe Z slowly for better resolution
exec.Wait(200);
Zmachposvariable = exec.GetZmachpos();
// Zmachposvariable = Zmachposvariable - Zmachposvariable - Zmachposvariable;
if(Currenttoolvariable == 1) // Write tool offset depending on current tool
  AS3.Setfield(Zmachposvariable, 196);
  AS3.Validatefield(196);
if(Currenttoolvariable == 2) // Write tool offset depending on current tool
  AS3.Setfield(Zmachposvariable, 197);
  AS3.Validatefield(197);
if(Currenttoolvariable == 3) // Write tool offset depending on current tool
  AS3.Setfield(Zmachposvariable, 198);
  AS3.Validatefield(198);
if(Currenttoolvariable == 4) // Write tool offset depending on current tool
  AS3.Setfield(Zmachposvariable, 199);
  AS3.Validatefield(199);
if(Currenttoolvariable == 5) // Write tool offset depending on current tool
  AS3.Setfield(Zmachposvariable, 200);
  AS3.Validatefield(200);
if(Currenttoolvariable == 6) // Write tool offset depending on current tool
  AS3.Setfield(Zmachposvariable, 201);
  AS3.Validatefield(201);
if(Currenttoolvariable == 7) // Write tool offset depending on current tool
  AS3.Setfield(Zmachposvariable, 202);
  AS3.Validatefield(202);
if(Currenttoolvariable == 8) // Write tool offset depending on current tool
  AS3.Setfield(Zmachposvariable, 203);
  AS3.Validatefield(203);
if(Currenttoolvariable == 9) // Write tool offset depending on current tool
  AS3.Setfield(Zmachposvariable, 204);
  AS3.Validatefield(204);
if(Currenttoolvariable == 10) // Write tool offset depending on current tool
  AS3.Setfield(Zmachposvariable, 205);
  AS3.Validatefield(205);
exec.Wait(100);
exec.Code("G43 H" + Currenttoolvariable); // Hämta ny tool offset
exec.Wait(200);
exec.Code ("G53 G00 Z" + ZRetractHeight); //Retract Z axis
exec.Wait(200);
exec.Code ("G90");
exec.Wait(100);
exec.Callbutton(168); //Apply
exec.Wait(100);
exec.Callbutton(167); //Save
